Munts316i
paint advice
While painting the undie van this year i seem to have got some little black dots from spray can overspray on my white beemer. any advice on how to take it off? the buffer is at home in the north island. is a professional valet the best idea?
Cheers
Alistair
Cheers
Alistair
Thinners?
Careful with thinners, can damage the clear coat. Would try cut and polish myself?
pwned,
go pro. they will whip that sh*t off real quick, even your local panel and pain/t shop will set you right
Can try a clay bar first before any cut polish.
2000 grit wet sanding is another idea. Need a polish after that though.
Otherwise, if there's only a few dots, the you can try to scrape the overspray **VERY CAREFULLY** with a blade.
Im a groomer part time, we use a product called "prepare it" most painters use it as well. But its a commercial product not too sure if you can get it at any old place.
Where can you buy clay bars from??
Its good to see karma has come to get you after destroying my beautiful city!!! :P
