tibbs.james 1 Report post Posted October 6, 2007 (edited) Just done the 5 speed swap on my E30 Got a good Getrag 260 ect New shift mount bushings Shifter appears to be in good nick, however i did not see the bushing where it sits in the shifter mounting plate as i had my gearbox man put that togeather as i had no circlip pliers. Car drives fine and you can always get the right gear first time ect. But once in gear it just wobbles around a bit like it slops around a lot more than other cars i have driven. Could the problem be in the clips for the linkage rod. Might it be the wrong shifter used ? it just feels not so flash is all. Also while i am here what short shifter kits are avalible ? I remember seeing one on trademe a while back but i can't find the listing. any help appreciated. Edited October 6, 2007 by Jimmy Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted October 6, 2007 (edited) replace the shifter rod and the end near the box . also the the round ball part sticking out from the gear box wears down were the pin goes through . also the plastic bush the geaqr lever ball joint sits in Edited October 6, 2007 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
cpelectrics 0 Report post Posted October 8, 2008 replace the shifter rod and the end near the box . also the the round ball part sticking out from the gear box wears down were the pin goes through . also the plastic bush the geaqr lever ball joint sits in Did that work Jimmy as I have the same problem??Thanks Quote Share this post Link to post Share on other sites
