scoobiesnakz
e30 diff noise
we have two e30 318i both have a rumbly noise\vibration coming from the rear on light de-acceleration mainly when going down a hill and slightly backing off the throttle anyone got any ideas
Theres a lot of info on the forum on this and similar issues if you have do a search for it. This is a known issue with the E330 and as the last poster said could be caused by a range of things. The good news is that it usually isnt expensive to put right if you can do the work yourself - the bad news is that it can be a $%^& to track down the cause
