nath 184 Report post Posted May 29, 2004 my back seat looks a little 'plain'. is it possible to retro fit headrests? would it simply be a matter of taking them from the rear or a 4 door (including the tubes they slide into)? or is it really not worth it? Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted May 29, 2004 doable, looks cool in leather. You need the bracket for inside the seat tho. Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted May 29, 2004 all you nead are headrests and brackets, the mounting locations are already in your seats, you just have to poke holes in the top for the headrest mounts to go through. Quote Share this post Link to post Share on other sites
nath 184 Report post Posted May 29, 2004 oh k, so this is a simple task? how much pulling apart does it require? thanx :thumb: Quote Share this post Link to post Share on other sites
Killa B 0 Report post Posted May 30, 2004 oh k, so this is a simple task? how much pulling apart does it require? thanx :thumb: Not much, just have to pull out the rear seat (lift straight upwards with a little force) and theres 2x 10mm bolts (one either side of the backrest) undo those and the backrest pulls out to, then it's pretty straight forward from there, B. Quote Share this post Link to post Share on other sites
nath 184 Report post Posted May 30, 2004 thanx 4 that, will try as soon as i can find me sum headrests...... Quote Share this post Link to post Share on other sites
