pureboiracer
pressure regulator
does anyone know where i can get a mechanical pressure regulator. that does not run off manifold vacume and can handle around 3 bar? prerebaly an adjustable one? cheers oli
I thought the pressure regulator's vacuum attachment was purely about allowing the regulator to increase fuel supply as the manifold pressure increased (so the injectors "see" a constant pressure with respect to the pressure in the inlet). Each 1 psi of inlet pressure leads to 1 extra psi of fuel rail pressure.
So (guessing a little here), disconnecting the vacuum source should just leave the pressure fixed at the standard rate?
Anyways, I've seen the D-Jet one part way down this article used in an aftermarket EFI setup - adjustable, no vacuum:
http://www.autospeed.com/cms/A_2637/article.html
Edited by CamB
