far4ngn
1996 E36 Rear Wash/Wipe
Ok the rear wiper on the Compact work fine, but the wash function doesnt work.
I've checked the rubber hose on the rear wiper and this is clear, the washer pump with the hose removed works well.
However, I blasted some air down the pipe to the rear of the car, all I got was rusty water coming out?? Somewhere in the wash system is their a valve of some kind to stop water running back etc? Just wondered if this has rusted and is blocking the water flow?
Any ideas>
Yup the valve is a one-way valve, and has been the culprit in many instances where the washing system doesn't work. I believe it blocks up. I'm not sure if you can clean it, but what some others have done is just buy a new one from the dealer, apparently it's not expensive.
