deane30 30 Report post Posted November 14, 2007 hi guys, I have recently noticed that whenever it rains or I wash my car I get s amall pool of water on the carpet in front of the drivers seat. There doesn't seem to be a trail of water from the door, though when i examined the door the rubber seal was cracked at the bottom. Any ideas on the cause? BTW the car is a 1988 e30 THANKS!! Quote Share this post Link to post Share on other sites
Kpax 0 Report post Posted November 14, 2007 Hey dude, I've got water in my car aswell & currently investigating it. But it sounds like you have a hole near one of your looms or a rust crack as it only happens when it rains or when you wash your car, to really be sure, remove the carpet & check the walls thoroughly. You will be suprised. Cheers. Quote Share this post Link to post Share on other sites
deane30 30 Report post Posted November 14, 2007 Hey dude, I've got water in my car aswell & currently investigating it. But it sounds like you have a hole near one of your looms or a rust crack as it only happens when it rains or when you wash your car, to really be sure, remove the carpet & check the walls thoroughly. You will be suprised. Cheers. Thanks mate, Do you mean a rust crack on the floor of the car? Also, Whats the easiest way to remove the carpet? Thanks again Quote Share this post Link to post Share on other sites
Kpax 0 Report post Posted November 14, 2007 Check for rust along the loom holes along the wall. Just lift the carpet backwards, but depends on how much you want it out , then you wiil have to remove your seats & console. Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 14, 2007 Drivers side is more likely to be at the back of the battery tray. Quote Share this post Link to post Share on other sites
pfm 0 Report post Posted November 14, 2007 re Drivers side is more likely to be at the back of the battery tray. My bet also - or down the window glass - into door internals and dribbly do on to the floor. If it only happened when it rained - contact the Real Estate people ! Paul - E30 Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted November 14, 2007 Mine did exactly the same thing had me dumbfounded, found a tiny tiny crack of rust behind the sound deading behind the battery tray, underneath where the wipers are attached (round abouts there) and took out carpet and tested it, dribbled in that way nicely, no trail, just dripped onto the carpet, Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted November 14, 2007 Or more likerly, the drain hose in the firewall from wiper motor cavity is blocked which means the cavity fills up with water and overflows into the cabin via the heater system. Hose is on the firewall above where the steering linkage goes through the firewall. Its a flat, oval downpipe. Just remove it entirely. Quote Share this post Link to post Share on other sites
