Braeden320
Power Steering
Hey All,
My power steering pump is noisy and gives very little assitance at low revs, not to bad when it has revs tho
There is also small peices of metal in the oil.
Would be the power steering pump on its way out?
The car is a 1998 Bmw E36 320i M-Optioned(not that it makes a difference to the engine)
Appriciate any help, if it is the pump also does anyone have a good second hand one or is new the way to go?
Braeden
Edited by braeden.
pieces of metal in oil could be the pump on its way out mate, happened to me a while back. thats getting metal through the steering rack too so you should probably fix it sooner rather than later.
Went to the old mans workshop and pulled it apart this morning.
Bloody handy having access to a hoist,parts cleaner and heaps of tools!!!
Was a peice of piss to pull apart
Fair bit of metal and scoring in the pump, was also lowish on oil.
Posted up some pics that i took with my phone to make the thread more interesting, :D
Edited by braeden.
Call or text me 0212435526 for a replacement.
Regards Ray
HELLBM
Regards Ray
HELLBM
Cheers Ray, ill take one.Will give you a call tomorrow.
Do you need part numbers?
