hybrid
Multi Functional Steering upgrade
Just a note on this,
if you have the N46 Engine that my 2004 318Ti Compact does then your connection to DME for the cruise control will be different
Look at these instructions http://thegannet.bulldoghome.com/CCInstructions.pdf which includes the N46 engine.
Your DME will have two connector blocks, take off the smaller one and remove the BLACK 26 pin connector from the block.
You need to attach the Cruise control cable to PIN 4, there will possibly already be a Blue/white cable in pin 4, simply remove this and insert your cable.
THEN WHAMMY ITS ALL WORKING!
Just completed this DIY and the wife is very happy!
