zenetti 0 Report post Posted December 14, 2007 Hey guys - the ac fans in my E38 7 series have stopped working, all the controls still work and there is a light ticking when you try to turn the fans up. Any ideas - hopefully its a quick fix cheers Johno Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted December 14, 2007 Its probably the fan speed resistor block in the heater box. Some are coil type..some are blade type...depends Some are on the L/H side of the heaterbox...some on R/H side Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted December 15, 2007 Its probably the fan speed resistor block in the heater box. Some are coil type..some are blade type...depends Some are on the L/H side of the heaterbox...some on R/H side Cheers Glenn sounds like I need to book it in, should be too big a job I hope. Any chance before Xmas? Thanks Johno Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted December 15, 2007 Give me a call...I might be able to fit you in Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted December 15, 2007 Give me a call...I might be able to fit you inwill call you on Monday, cheers Quote Share this post Link to post Share on other sites
