isis 16 Report post Posted December 27, 2007 I think i've run out of gas - i haven't done the regassing since i've purchased it. Would like to know where you guys take your cars to and roughly what do they cost? Preferbly somewhere around greenlane/onehunga area if its at all possible. cheers Quote Share this post Link to post Share on other sites
eef48 0 Report post Posted December 29, 2007 I think i've run out of gas - i haven't done the regassing since i've purchased it. Would like to know where you guys take your cars to and roughly what do they cost? Preferbly somewhere around greenlane/onehunga area if its at all possible. cheers Quote Share this post Link to post Share on other sites
eef48 0 Report post Posted December 29, 2007 I think i've run out of gas - i haven't done the regassing since i've purchased it. Would like to know where you guys take your cars to and roughly what do they cost? Preferbly somewhere around greenlane/onehunga area if its at all possible. cheers I don,t live in your area but I can tell you as a qaulified Refrig engineer to take it to a proper auto A/C mech. places like Climatech will do it for you but most likely do a poor job of it. The problem is when they recharge the system the car is stationary so the discharge side of the system gets hot and the wrong amount of refrigerant gets put in.A/C mechs use a large fan to blow across the condensor to compensate for this.If the weigh in charge is written on the car its not so much of an issue but the label is usually missing. Also the A/C mechs have a travel lift so can get right under the vehical for a good look to make sure the gas hasn't escaped from a loose fitting some where hard to find. Quote Share this post Link to post Share on other sites
localdevdas 2 Report post Posted December 29, 2007 try www.coolcar.co.nz heard they do free a/c check-ups as well.......... Quote Share this post Link to post Share on other sites
isis 16 Report post Posted December 30, 2007 cheeers Quote Share this post Link to post Share on other sites
