tintop 10 Report post Posted January 2, 2008 I need a pinout diagram or at least the pairs of pins for the each wheel sensor for the ABS, have found the ABS module behind glovebox but the pinout diagram is for a 55 pin board, mine has around 40 or so. thanks Quote Share this post Link to post Share on other sites
tintop 10 Report post Posted January 2, 2008 Just checked each wheel sensor instead. They were all 1.1k resistance so its not the sensors Have d/c the battery to reset OBC. Hopefully clears the ABS light, if not its off to BMW. Quote Share this post Link to post Share on other sites
HELLBM 1695 Report post Posted January 3, 2008 I have sold 4 ABS units in the last month. Not uncommon for the seals to disintigrate. The trend seems to be with one particular type common to the 328`s regards Ray 0212HELLBM Quote Share this post Link to post Share on other sites
