petone 0 Report post Posted June 14, 2004 Hi guys, my pads are almost gone and I was thinking instead of some replacing em' with the normal ones that I should spend some extra bling and get decent ones. I will probably replace the rotors as well. Anyone got suggestions? What are you guys running? Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted June 15, 2004 For a 318i - use the stock brakes.. the 4 disc setup stops pretty well when its all nice and setup properly. Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted June 15, 2004 for shizzle the linkizzle Quote Share this post Link to post Share on other sites
petone 0 Report post Posted June 15, 2004 Thanks but I've had a look at that. I was just looking for any pads or rotors that people have had good (or bad) experiences with. Quote Share this post Link to post Share on other sites
Dnz 0 Report post Posted June 15, 2004 With bimmers its usually good to use stock pads if you got stock rotors, otherwise you get baaad brake squeal.. (on e36 anyway).. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted June 24, 2004 Just finnished setting up the race car, 323i e30. Rolled it targa last year. Went to possum bourne Motorsport to get a set up to make the best package for club sport use. we used Brembo rotors and metal king pads. no squeal. ran this car in sprint series at manfield last year then targa. pads now half worn and rotors still like new. cost not much more than stocks and are incredible. Also use valvoline race brake fluid, higher temp and better feel when HOT. expensive at 30.00 for 500ml but worth the money. New to this site but enjoying. :bowdown: Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 24, 2004 are you still using the stock calipers? does the race series rules mean you must use the stock calipers? are the brembo rotors slotted and the same size and original? Quote Share this post Link to post Share on other sites
threeta 0 Report post Posted June 25, 2004 try ebc from hi tech brake and clutch - no black dust!!! last ages and keep on stopping. hi tech www Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted June 25, 2004 we used Brembo rotors and metal king pads. no squeal. ran this car in sprint series at manfield last year then targa. pads now half worn and rotors still like new. valvoline race brake fluid, higher temp and better feel when HOT. nice combo dude, metal kings are supposed to be quite nice too..welcome to the site Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted June 25, 2004 Hey Hartage, nice post to break the seal, nice ot see you enjoying. Come along to the meet next sat (3rd) if you can. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted June 25, 2004 Hi welcome to the site, I'm pretty new as well. Thats the sort of info I was after. I was think about the brembo rotors but am undecided on pads. I've got motul fluid to put in which hopefully will be good. While you only use your car for competition I use it everyday so I need something with reasonable life, still your set up is holding up well. And that was all purchased through PBMS? Quote Share this post Link to post Share on other sites
