Muzzie
WTD - Brake Light Sw For E36
As above, gfs 94 318iS brake light switch has finally given up for good. Managed to dogy it through a couple of wofs but well and truly gone to the after life now.
So yeah, I need one! :D
Cheap too hehe
i dont know if the brake light switch is different to a std one.I wouldnt go for a second hand one,its ikely to be in much the same condition to yours....go to the dealer and buy one,it will be less than a tank of gas .
I agree, if you buy a secondhand one it probably won't last as long as a new one, seeing as this is a common problem. In the long run a new one might save you time and money.
Yep as said - definitely new, common problem - I have replaced several in customers cars over time
