Roshen
help.. circut in a e30
I have replaced the head unit with a EQ in the car
the problem i have is: the Tach, economy meter and clock now does not work (the EQ does). the only cables i used are power, ground and ignition, from the unit that was already there.
i know they all are on 1 circuit, what i need to know is if i dont want the Head unit in the circuit, how can i bypass it
EDIR: fixed now - Boot Light causing all the sh*t
Edited by Roshen
What colour wire did you use for ground?
brown / black - Ground
red /green - Power
purple / grey - Acc
