Driftit 2219 Report post Posted January 22, 2008 My brake check light came on during the weekend. And found that I have no brake lights. Sometimes I get one though. Checked all the fuses and found a blowen one. Replaced it. Then about 20 mins later it popped again. Changed the two brake light bulbs just in case. Cleaned all the contacts for them. Is there any common faults I can check for? Quote Share this post Link to post Share on other sites
Brennan 0 Report post Posted January 22, 2008 its almost always the brakelight switch above the brake pedal. Mine needs adjustment every so often. Quote Share this post Link to post Share on other sites
M3 Cab 0 Report post Posted January 22, 2008 its almost always the brakelight switch above the brake pedal. Mine needs adjustment every so often. Yeah had the same fault easy to fix Quote Share this post Link to post Share on other sites
Driftit 2219 Report post Posted January 22, 2008 THought it would be something like that. Will check it 2moro. Just pulled the one off the spare peddle box I have. Broken. lol Quote Share this post Link to post Share on other sites
