tcbaurpower 5 Report post Posted February 5, 2008 Hello The e28 is sitting nice and low in the front. The problem with that is i now have a cracked sump and therefore a seady oil leak . I have found a guy with a e34 520i sump which looks great so all i need to know is will it fit on my 1987 525i? Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 6, 2008 As far as I know, the e34 520 is the M20 engine and your E28 525i is the M30, in which case it won't fit. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 6, 2008 the 2.5 will be the m20 too,but the sumps could still be different. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 6, 2008 Not necessarily, I've got an E28 525i here which has the M30 engine. I'm fairly sure all E28 525i's are M30's, the M20 was used detuned in the 525ee? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 6, 2008 as far as i know the m30 was either a 3 or 3.5(or maybe a 2.8) in the E28 Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 6, 2008 (edited) Just checked and all E28's are M30's from 525i and up. So the M20 sump won't fit. Edited February 6, 2008 by Silver Fox Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 6, 2008 Most e28 2.5 are M30, the e28 525e uses the M20 2.7 . I think maybe some of the earlier e28 might have used the m20 2.5 but I have never seen one. (watch BMW prove me wrong here.. ) You will see on the intake manifold 2.5/2.8 or 3.2/3.5 or 3.3/3.5 cast into it. If it has the dizzy sticking up above the front of the motor it is the M30, I don't think the M30 2.5 ever used the motronic. I would doubt if the sump off an e34 would fit the m30 motor but as I have never tried it, you never know.. Will Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 6, 2008 Thanks for the replies , as i thought it is not that simple. The sump did look like it was on a different angle. The intake manifold has 2.5 / 2.8 on it like the photo. Is it worth getting it, only $40, to give it a go? Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 6, 2008 Waste of money, won't fit, you have the M30 motor, better to ask if anyone has one. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 6, 2008 ahaaa live and learn.......thanks for the info! Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 6, 2008 525i is M30B25 , 525e is M20B27 , i have a M30 sump for a e28 . $180 . 021433600 cheers brent Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 6, 2008 Okay so a e34 520i engine is a M20 what is a e34 525i engine are they M30? I have seen a list some where but can not find it now! Thanks Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 6, 2008 M20 as well AFAIK. Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 6, 2008 e34 does not use the M30 motor in 2.5 configuration. Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 6, 2008 Well i will just try and find another e28 then. Hey thanks that saves me time and money. Poor car will just have to leak for a while longer. Cheers Adam Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 6, 2008 (edited) Yipes, just measured my sump on my e28.... 65mm... wooooops!! Need to fit a sump guard urgently! Wonder if I can mod an e30 one to fit?? The way I drive I won't just crack it if I hit anything, hahahahaha Will Edited February 6, 2008 by will Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted February 6, 2008 Worst Case Senario you could get it Mig welded back up, A decent engineering place should be able to do this no trouble at all. If a broken Cast Iron Exhaust manifold can be re welded up surely Cast alloy could be welded by the right person. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 7, 2008 i have one left in stock ... $180 . 021433600 Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 9, 2008 i have one left in stock ... $180 . 021433600 That would be great but you are so far away. I have found some sumps in christchurch off e28's but they are 3.0L and 3.5L will this fit? Worst Case Senario you could get it Mig welded back up, A decent engineering place should be able to do this no trouble at all. Yes i have already asked about this and just thought it would be stronger and easier to just replace it. You have to remove the sump and degrease it before you can weld it anyway. Cheers Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 9, 2008 That would be great but you are so far away. I have found some sumps in christchurch off e28's but they are 3.0L and 3.5L will this fit? Yes i have already asked about this and just thought it would be stronger and easier to just replace it. You have to remove the sump and degrease it before you can weld it anyway. Cheers snail mail will be quite cheap....You will have to remove it any way.....might be quite good to have a standby???? Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 9, 2008 That would be great but you are so far away. I have found some sumps in christchurch off e28's but they are 3.0L and 3.5L will this fit? Yes i have already asked about this and just thought it would be stronger and easier to just replace it. You have to remove the sump and degrease it before you can weld it anyway. Cheers $200 freighted 021433600 . Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 9, 2008 I have found some sumps in christchurch off e28's but they are 3.0L and 3.5L will this fit? Cheers Yes those will fit. As you say, alley has to be spotless before you can weld it successfully, I normally grind the crack open with a dremel tool to remove all traces of oil and then take it to be welded. Will Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 9, 2008 Yes, E28 3.0 and 3.5 should fit, same block as far as I know. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 10, 2008 a 530i e28 , that would be pretty rare , me thinks it might be a e12 or a e34 type Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted February 10, 2008 Well i will just try and find another e28 then. Hey thanks that saves me time and money. Poor car will just have to leak for a while longer. Cheers Adam The sump on your car was used on E23 728, E24 628CSI, E28 525 & 528 Quote Share this post Link to post Share on other sites
