no_fat_chicks 1 Report post Posted February 7, 2008 1) My fog lights don't work. the rear ones work but not the front ones. I press the right switch, not even the green light lights up on the dash. 2) where the auto shift lever is located, those lights don't light up either e.g. 'P,R,N,D,3,2,1' does not light up. 3) where the headlight knob is, is it meant to be lighted? also, where the switches for the foglights are located, theres a red plastic strip, is it meant to be lighted as well? anyone know a good sparky in auckland? Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted February 7, 2008 1) My fog lights don't work. the rear ones work but not the front ones. I press the right switch, not even the green light lights up on the dash. 2) where the auto shift lever is located, those lights don't light up either e.g. 'P,R,N,D,3,2,1' does not light up. 3) where the headlight knob is, is it meant to be lighted? also, where the switches for the foglights are located, theres a red plastic strip, is it meant to be lighted as well? anyone know a good sparky in auckland? (1) Fuse,Relay or switch faulty (2) Should just be a bulb (3) I'm pretty sure the answer is no or mines knackered too ....Will will know he has more E30 experience I can recommend Blair Woodhead (Woodhead Electrical) in Panmure Ph. 5704540 Cheers Glenn Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 7, 2008 There is a globe behind the light switch which should come on when you turn the ignition on. It is a small push in one like the one that should be under the gearlever. Foglamps use fuses 29, 30 and relay K8. K8 needs to be a double pole relay and is normally black in colour. Maybe the green globe is blown also?? Will Quote Share this post Link to post Share on other sites
no_fat_chicks 1 Report post Posted February 8, 2008 (edited) what are the switches in the red circles for? those dark red plastic strips above the headlight knobs, are they mean to be illuminated too? whats this light for in the dash? sorry about all the nooby questions. first bimmer, hehe. Edited February 8, 2008 by no_fat_chicks Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 8, 2008 (edited) what are the switches in the red circles for? Top right, ciggy lighter bottom right, this disables all the electric windows and acts as an overload too. left one(small square one), disables the rear windows only those dark red plastic strips above the headlight knobs, are they mean to be illuminated too? Yes, there is a small globe behind the panel that will illuminate when you turn the ignition on. whats this light for in the dash? Brake pad warning light, tells you your pads are low (as long as you still have the sensors on the wheels, some people bypass them as they are too cheap to replace the sensor when it is damaged by running the pads too low). sorry about all the nooby questions. first bimmer, hehe. Enjoy it, looks good with all the toys including the OBC and cruise control. Will Edited February 8, 2008 by will Quote Share this post Link to post Share on other sites
no_fat_chicks 1 Report post Posted February 8, 2008 (edited) "looks good with all the toys including the OBC and cruise control." whats the OBC? and is the gear console meant to be illuminated? Will, thankyou Sir for your help. You really know ur bimmers! Edited February 8, 2008 by no_fat_chicks Quote Share this post Link to post Share on other sites
no_fat_chicks 1 Report post Posted February 8, 2008 OBC - on board computer, hehe, I guess a little searching on google can do wonders... Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 8, 2008 "looks good with all the toys including the OBC and cruise control." and is the gear console meant to be illuminated? Yes, there is a small globe that is attached to the gear lever to show you what gear you have selected, see pic.. Quote Share this post Link to post Share on other sites
no_fat_chicks 1 Report post Posted February 8, 2008 oops! I will have to take it to a sparky. Quote Share this post Link to post Share on other sites
