tcbaurpower 5 Report post Posted February 9, 2008 Hello, I have taken the gearbox and engine out of the 1986 e30 325i and because I don’t have any service record I wanted some advice as to what may need to be replaced and good products to use. This is what I was going to do - oil and oil filter, coolant, fuel filter, air filter, gearbox oil, power steering fluid, clutch fluid and brake fluid. The engine bay had a sticker with a picture of the timing belt cover and the miles done since then about 3,000. Is the cam belt usually done at the same time? I was also going to give it a good scrub down so I can see if there are any leaks. Since I have the gearbox off I am interested to know if there are any sport clutch plates and flywheels, just thought it would be a good idea to replace these since it is such an annoying job to get the gearbox off. Are there any websites to look at? Cheers Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted February 9, 2008 Cam/timing belt the same thing, I would check it while engine is out. Depending on milage, probably replace cam belt, tensioner, water pump (needs cam belt off for that) - these all much easier when out. Check oil leaks before cleaning or you will never see where it has come from (different story when engine still in & running) I would suggest replacing all frost plugs while out - I have had to replace a few in place & some of them can be a real %$##^* to access in situ - easy when out. I would also replace rear main seal, standard clutch quite OK IMO Obviously repair any leaks you confirm while engine is out Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 14, 2008 Cam/timing belt the same thing, I would check it while engine is out. Depending on milage, probably replace cam belt, tensioner, water pump (needs cam belt off for that) - these all much easier when out. Check oil leaks before cleaning or you will never see where it has come from (different story when engine still in & running) I would suggest replacing all frost plugs while out - I have had to replace a few in place & some of them can be a real %$##^* to access in situ - easy when out. I would also replace rear main seal, standard clutch quite OK IMO Obviously repair any leaks you confirm while engine is out Hello, Good points to note, i have one questions on your answers, rear main seal? can you give me a pick maybe off the OEM site. Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 14, 2008 Do the sump as well, dont use the cork gaskets they now supply. Clean block & sump with white spirits and use grey Eurothane sealant ( Panelbeating Supplies) Ring me for more info Ph.(09)2722546 Do not use sylicon Cheers Glenn Quote Share this post Link to post Share on other sites
