pureboiracer 0 Report post Posted February 9, 2008 hey guys. i got a 325i the other day. it has the pfl computer system in it with the mechanical dizzy in the side of the block. is this l.jet or k.jet? and it currently is running on a 323i ecu. so i need a 325i ecu for it. can anyone help me out? Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted February 9, 2008 With Dizy on the side of the block, its L Jet. 325i never ran L Jet computer so this has been swapped into the car. You wont find a computer ( as far as i know ) that will sort your problem. All 325i ran Motronic either pre or face lift ( 2 versions ) Need to change the loom to match the motor. best is to use Face lift as its a more useable loom, less sensors ! Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted February 9, 2008 hi , you could try a l-jetronic ecu from aM30 engine 2.5L or 2.8L from a e28 525i or 528i . 525i as rated at 150Hp the 528i was 175hp same as M20 325i engine . they run pretty much the same type engine senors etc . worth a try . or just convert to later motronic system but you will have to add sensors to fltwheel and bellhousing or to front of engine with new damper depending on which year motronic you choose to use . what year is the engine that has been used ? i have some ecu's too 021433600 Quote Share this post Link to post Share on other sites
