QuickSilver 0 Report post Posted February 17, 2008 (edited) Hey everybody, I was just wondering, which bushes would be the best to replace in terms of steering, would replacing any tighten up the steering at all? Also, where to buy and what price range am I looking at? Nolathane or poly urethane? Any info appreciated! Cheers Alex. Edited February 17, 2008 by QuickSilver Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted February 17, 2008 ah yes, thought so, and if I were to do a set at a time, which are the most urgent? Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted February 17, 2008 Powerflex bushes are good. You can get them from the NZ distributor www.dynamicraceparts.com PFF5-301 Front CA bushes ( 2 per car ) $48.00 + GST each x 2 = $96.00 + GST = $108.00 PFF5-302-19 Front Sway bar bushes for 19mm sway bar (also available for 22 and 24mm bars) ( 2 per car ) $39.00 + GST each x 2 = $78.00 + GST = $87.75 PFR5-305 Rear subframe bushes (2 per car ) $81.00 + GST each x 2 = $162.00 + GST = $182.25 PFR5-306 Trailing arm bushes ( 4 per car- 2 x inner 2 x outer) $57.00 + GST each x 4 = $228.00 + GST = $256.50 PFR5-308-12 Rear Sway bar bushes for 12mm bar (also available for 14, 16, & 18mm bars) ( 2 per car ) $39.00 + GST each x 2 = $78.00 + GST = $87.50 Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted February 17, 2008 Thanks guys, will start getting onto them in the order suggested, thanks for the prices Bravo, will be getting some this week. Quote Share this post Link to post Share on other sites
