vanos
Key replacement
Gidday. I would like to replace a lost key. I have a 1996 e36 323i and it is was a keyless entry key. I live in Queenstown and have no dealership. Meantime I do have the spare. Thanks in advance for any advice i.e. price and process.
Off memory, a transponder key is about $700.
A quick call to Dunedin should sort you out.
A key without the keyess entry for an E36 will cost you about $100, with the keyless entry about $450.
You need to get it from a dealer (I rung around trying to get one elsewhere, but got the same answer from everyone - "go to the dealer". You will also need proof of ownership of the car, and also the last 7 digits of your VIN.
Grant
Grant
correct .plus 1
