xtr041947 0 Report post Posted March 24, 2008 Hi, probably a question for Glenn at Botny Motorworx, I have a 2001 728, it has the vanos oil feed line weeping at the lower end, also possibly the sump gasket is leaking oil as well. Could you please give me an indication of the cost to get these issues fixed. Thanks in Advance. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 24, 2008 Hi, probably a question for Glenn at Botny Motorworx, I have a 2001 728, it has the vanos oil feed line weeping at the lower end, also possibly the sump gasket is leaking oil as well. Could you please give me an indication of the cost to get these issues fixed. Thanks in Advance. You might find its leaking from the oil filter remote housing gasket. How thoroughly did you check it ?? Quote Share this post Link to post Share on other sites
xtr041947 0 Report post Posted March 24, 2008 not overly... I will have another look tonight, and let you know. Quote Share this post Link to post Share on other sites
xtr041947 0 Report post Posted March 25, 2008 hi I checked it out. But unfortunetly really couldn't determine where the source of the leak was, this is of course using all my limited backyard mechanic skills. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 25, 2008 hi I checked it out. But unfortunetly really couldn't determine where the source of the leak was, this is of course using all my limited backyard mechanic skills. If your in Auckland...bring it in and I'll check it for you....please ring first though Quote Share this post Link to post Share on other sites
xtr041947 0 Report post Posted March 25, 2008 thank you so much , I will do. Out of interest are any of those things generally covered by a AA mechanical warranty? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 26, 2008 thank you so much , I will do. Out of interest are any of those things generally covered by a AA mechanical warranty? They may well be covered, I can check with them while your here Quote Share this post Link to post Share on other sites
