bwh1 0 Report post Posted March 30, 2008 I've just taken out an old electric aerial and installed a second-hand sony electric aerial. For some reason it goes about a metre plus up which isn't ideal for the garage or trees. Any ideas for adjusting this? Quote Share this post Link to post Share on other sites
bmw.maniac 1 Report post Posted March 30, 2008 Buy a new, shorter aerial? Or when its up you could kind of push it down to break it so it doesn't go up so far. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted March 30, 2008 Could always pull it apart and shorten the plastic thing that pushes the aerial up Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 30, 2008 Could always pull it apart and shorten the plastic thing that pushes the aerial up Can't, it will then unwind past end of cord on up stroke & not return. Short answer no - get a different aerial. You could switch the battery feed to it to interupt supply at the desired height but would be a pain to do this every time Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted March 30, 2008 Solution or An Alternative Quote Share this post Link to post Share on other sites
bwh1 0 Report post Posted March 30, 2008 Solution or An Alternative Quote Share this post Link to post Share on other sites
bwh1 0 Report post Posted March 30, 2008 Can't, it will then unwind past end of cord on up stroke & not return. Short answer no - get a different aerial. You could switch the battery feed to it to interupt supply at the desired height but would be a pain to do this every time Thanks for that. I'm thinking that pulling it apart and shorting the cord could be the go. Quote Share this post Link to post Share on other sites
bwh1 0 Report post Posted March 30, 2008 Could always pull it apart and shorten the plastic thing that pushes the aerial up Thanks for the thought. I'm thinking that shortening the cord will be an absolute pain, but potentially the way to go. Quote Share this post Link to post Share on other sites
bwh1 0 Report post Posted March 30, 2008 Buy a new, shorter aerial? Or when its up you could kind of push it down to break it so it doesn't go up so far. Thanks, kindof thought that it should have been a simple replacement since I took it out of another e30 which was stil runing the standard bmw audio equipment. Gonna attempt getting at the cord and shortening that. thks for the thought. Quote Share this post Link to post Share on other sites
