crobmw
17's and springs combo
selling the two below as a set:
project never started so wanting to sell these,both sets brand new!!
-17" TSW Trophies with new tyres 205/40/17 with lock nuts
-Jamex lowering springs 40mm
$2000 firm ,for the lot.
021-129-3763
17" are mad on E30's, got any pics of the mags???
Whats the offest? if its 40mm the Trophies will not fit without spacers. They clear the strut but don't clear the front brake caliper. I know this becuase i test fitted some just a week ago.
offset is 7.5 (am pretty sure).But I think you're wrong about needing spacers
as the mags were purchased brand new from Mag and turbo and I
think those guys knew what they are on about when they told me
these are perfect fit for E30's as they don't stick out / no need for guard
rolling or spacers.
They also come with rings shaped to fit the little bubble sticking out on
the drum and make the mags sit properly on the car.
I tried unsucessfully fititng 17"'s on my e30 today. 4x100 stud pattern with offset 40.
Back fitment seemed ok, but it didnt seem right on the front, the caliper was touching also.
So yeah i had a similar experience? what did you end up doing? :rolleyes:
Guest Andrew
rolling or spacers.
7.5 is wrong - will need to run a big spacer to get offset to 35mm
Does anyone know for a fact what the correct offset for an e30 is? After my experience today, i can tell you that an offset of 40 isn't right.
:wacko:
I'm running 20 with 7.5's
EDITED: In fact, you cn see by my sig pic that with 205's they only just snuggle under the arches
Edited by ///Carl
I never got them, was going to be too much hassle. The proper offset is ET35 (thats what it says on my spare anyway). Some 17's will fit if they are ET40, I have also test fitted some advanti mikano's (I think thats what they were) and they fitted fine, it will just come down to the shape of the wheel as to whether they clear the caliper or not. Also you should be able to run 215/40/17, I wouldnt go 215/45 cos the tires are too big.
Also 17's look wicked but i would prefer to be driving on 16's. The ride is better, easier on suspension and its a bit easier to control when you slide. (I have been told this)
