BMW316i
E30 headunit trouble
Looking directly at the front of the headunit there are 2 little panels on each side about halfway up. Use a little screw driver to open them up. Behind them there are 2 allen screws, undo these then pull your head unit out. Make sure you insert the allen key all the way in or you could strip the screw head. I assume you have the standard e30 antitheft headunit.
failing that use brute force and ignorance.
Well you could if you wanted to on your car. I know i wouldn't on mine. Youl'd be kicking yourself forever if you broke part of the dash.
yea thats true
just be patient with it and you will work it out
the long way is normally the easiest.. just time consuming
