kerrynzl 3 Report post Posted April 6, 2008 Does anyone know the Torque Settings of the Main Caps, Conrods, Front Crankshaft Bolt for a M50 / M52 Engine I've had others looking for me Apparently the Bentley doesn't have these settings [ they don't wanna be sued by some incompetent yank ] Its the hold up on my Stroker Engine right now What's the hot set up for installing "rings"? Do I use oil , CRC , or install dry in the ring compressor? Every engine "Guru" tells me different Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 6, 2008 Does anyone know the Torque Settings of the Main Caps, Conrods, Front Crankshaft Bolt for a M50 / M52 Engine I've had others looking for me Apparently the Bentley doesn't have these settings [ they don't wanna be sued by some incompetent yank ] Its the hold up on my Stroker Engine right now What's the hot set up for installing "rings"? Do I use oil , CRC , or install dry in the ring compressor? Every engine "Guru" tells me different Mains : 20-25 Nm + 47-53 degrees Conrods : 23Nm + 70 degrees Pulley bolt : 390-430 Nm I fit rings dry in pistons with a smear of light oil in the ring compressor & bore Cheers Glenn Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted April 7, 2008 Thanks Glenn, I can't believe the Torgue on the front Bolt. It's a pity I can't get that same rating out of the back of the crank , haha! Again, much appreciated Kerry Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 7, 2008 DISSCLAIMANT: Those torque settings were from AUTO DATA Not from me...... I just passed them on......lol Quote Share this post Link to post Share on other sites
