kerrynzl
M50 Bolt Torque Settings
Does anyone know the Torque Settings of the Main Caps, Conrods, Front Crankshaft Bolt for a M50 / M52 Engine
I've had others looking for me
Apparently the Bentley doesn't have these settings [ they don't wanna be sued by some incompetent yank ]
Its the hold up on my Stroker Engine right now
What's the hot set up for installing "rings"?
Do I use oil , CRC , or install dry in the ring compressor? Every engine "Guru" tells me different
Mains : 20-25 Nm + 47-53 degrees
Conrods : 23Nm + 70 degrees
Pulley bolt : 390-430 Nm
I fit rings dry in pistons with a smear of light oil in the ring compressor & bore
Glenn
Thanks Glenn,
I can't believe the Torgue on the front Bolt.
It's a pity I can't get that same rating out of the back of the crank , haha!
Again, much appreciated
Kerry
DISSCLAIMANT:
Those torque settings were from AUTO DATA
Not from me...... I just passed them on......lol :P
