QuickSilver 0 Report post Posted April 8, 2008 (edited) Hey everybody, I have just pulled a large case side loader LSD, from a 79 e24. (635csi) I cant be certain on ratio, however some research has dug up that all euro spec'd 635csi's which were mated to a dogleg box had a 3.07 ratio because of the 1:1 fifth gear, please correct me if I'm wrong. I'll happily straight swap for an LSD that will go into my e30 Diff is in good nick, has a bit of grime on it, just mud and dirt etc, no leaks and is in good condition. Along with this diff, a 5 speed dogleg with 1:1 fifth gear, and clutch assembly, Have everything needed for a manual conversion. Sorry for the name edited post after I made the thread. I am also after a few things for my e30, PM me for details on price and/or a possible deal. Pics below. While I'm at it, I'm parting this e24 and have most parts, if you need something I''ll check and see if I have it and post up a price. Interior pretty much totaly rotten, and alot of rust in the body. Open to BS members only at this stage. Cheers. Alex. Edited April 8, 2008 by QuickSilver Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 8, 2008 Large case or Medium? Should fit your E30, just need to swap the back plate and output shafts. Diffs from E28, E24, E23 and E30 are all the same fitting and interchangeable, just need to swap the above to get to fit. Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted April 8, 2008 really? what do you mean by back plate? This is the diff, would the ratios be way out of wack for my m20b20 though? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 8, 2008 No, that won't fit will it? must be large case as you said. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted April 8, 2008 (edited) looks like an old butter churner Edited April 8, 2008 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted April 8, 2008 yeap, large case side loader, apparently rarer than the later versions, wasnt quite if that would bolt into the e30 lol! Quote Share this post Link to post Share on other sites
