jjs 64 Report post Posted April 10, 2008 How much would a manual conversion on this cost? I'm guessing you need an M3 box... Could be a steal at $17k Trademe Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted April 10, 2008 Yeah that's what I thought too... looks like a pretty good deal for a 1999 M3. Quote Share this post Link to post Share on other sites
mr E34 11 Report post Posted April 16, 2008 FAB BMW dismantlers in the UK convert E46 M3 SMG boxes to manual.They convert and sell with engine packages etc, E36 prob diff. Just more useless info. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 16, 2008 i have a gear box for this..just needs other manual bits! Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted April 16, 2008 (edited) the smg gearbox is the same as the manual one, all of the hydraulic bits are just bolted on.So you will need a gearlever,obviously a pedal box too, not sure how the engine computer will respond to having the trans. disconnected, possibly can get around that though. I would give it a go, worst case scenario is that the fault is in the gearbox causing it to jump out of gear. Edited April 16, 2008 by conrod Quote Share this post Link to post Share on other sites
318isCoupe 0 Report post Posted April 16, 2008 the smg gearbox is the same as the manual one, all of the hydraulic bits are just bolted on.So you will need a gearlever,obviously a pedal box too, not sure how the engine computer will respond to having the trans. disconnected, possibly can get around that though. I would give it a go, worst case scenario is that the fault is in the gearbox causing it to jump out of gear. So if the computer calls foul it could just be Link swap and you're away. Still sounds like a pretty decent buy to me. Quote Share this post Link to post Share on other sites
