wild_weston 0 Report post Posted April 14, 2008 (edited) Anyone have any ideas where I can pick up an EOM alarm system. Obviously I can get it through BMW dealers but they mark up their part prices quite a bit. Seems easy enough to install. Cheers Edited April 14, 2008 by wild_weston Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 17, 2008 Anyone have any ideas where I can pick up an EOM alarm system. Obviously I can get it through BMW dealers but they mark up their part prices quite a bit. Seems easy enough to install. Cheers OEM is not available. You need a Mongoose Map Upgrade kit. That works of your original key. Its called: Map80 Series Upgrade Should cost you about $550 + GST fitted You might be able to get it fitted cheaper down in Wellington Thats my alarm tech's price Cheers Glenn Quote Share this post Link to post Share on other sites
wild_weston 0 Report post Posted April 17, 2008 OEM is not available. You need a Mongoose Map Upgrade kit. That works of your original key. Its called: Map80 Series Upgrade Should cost you about $550 + GST fitted You might be able to get it fitted cheaper down in Wellington Thats my alarm tech's price Cheers Glenn Cheers for the info. I was wondering why the dealer said no. I've rang mongoose and they said RRP was 550 installed. Going to try a couple of mongoose suppliers to see if I can get this price. Thanks for all your help. Quote Share this post Link to post Share on other sites
