Markq 0 Report post Posted April 15, 2008 Hi. Do E34 and E39's share the same wheels??? Stud pattern etc. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 15, 2008 Hi. Do E34 and E39's share the same wheels??? Stud pattern etc. yes Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted April 15, 2008 yes Ta. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted April 15, 2008 (edited) Ta. NO not exactly... Same stud pattern yes, but E34 (specific eg. OEM) wheels will not fit on an E39 as the wheel centre bore is different (72.5 Vs 74mm). E39 wheels will go on a E34, but you "should" use hub centering rings. So it depends what you are trying to do!?!?! E34 to E39 or E39 to E34!?!?! [shameless plug] I have a set of 17x8's for a E39 if you were in the market for wheels (brand new)[/shameless plug] Edited April 15, 2008 by E30-323ti Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted April 15, 2008 NO not exactly... Same stud pattern yes, but E34 (specific eg. OEM) wheels will not fit on an E39 as the wheel centre bore is different (72.5 Vs 74mm). E39 wheels will go on a E34, but you "should" use hub centering rings. +1 Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted April 15, 2008 Yeah....what Glenn said Quote Share this post Link to post Share on other sites
