JiB 2 Report post Posted April 15, 2008 As above. It's a PFL 328i with the rain-sensing function...the wipers have just stopped working completely? Still sprays the window washer though.. Have checked the fuses but all seem intact..can it be a ground to a wiper motor or something? Help please Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 15, 2008 As above. It's a PFL 328i with the rain-sensing function...the wipers have just stopped working completely? Still sprays the window washer though.. Have checked the fuses but all seem intact..can it be a ground to a wiper motor or something? Help please You'll need to get it checked. Its probably the wiper stalk switch. I've replaced a couple so far. How did you check the fuses ??? with a test light or a volt meter. I've struck quite a few fuses that are cracked, will test ok with a test light (led) but wont take load. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted April 16, 2008 They started working perfectly again.... I didn't do anything, maybe it's a dicky switch? Will check it out. Cheers. Quote Share this post Link to post Share on other sites
