E28 Master of diguises
clutch switch
hey there ppl i need some information on the E28 if there are any ppl out there?
what i would like to know what does the button or switch mechanism underneath the accelerator is ie information on why is it is installed in the car what it is used for etc
this is the first time that i have come across this
if its like e30s its there for kickdown on automatics
clutch switch is for cruise control
Hay bro
i got a e28 and its the automatic kickdown switch, which isnt used on all auto's that are in the cars, you either have that switch as your kickdown or one on the throttle body for a mechanical kickdown
if you are going to play with it if your auto is electronically control dont forget if i remember right you have to adjust two bolts to hold it in place, but both easyish to get at
