bumpstop325 0 Report post Posted July 13, 2004 i need a 2.7 block out of an e28. dosnt need to have the head. just the block, crank, pistons and sump Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 13, 2004 Tim - you could just use the crank. What pistons are you planing on using? The 325e pistons won't work. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted July 13, 2004 i want the 2.7 block. 'i' head on a 'e' block Quote Share this post Link to post Share on other sites
318i Turbo 0 Report post Posted July 13, 2004 from wat i beleive the 'e' block and the 'i' are the same thing and its the crank that gives the more cc's?? Quote Share this post Link to post Share on other sites
petone 0 Report post Posted July 13, 2004 Quote 'i' head on a 'e' blockI not sure on this but i'm sure I read somewhere that this doesn't work too well. Something about the shape of the pistons means that you get lower compression. Why not just do what andrew said and get the crank? Are you planning on using the 282 cam that you got? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted July 13, 2004 i have read about it on the BEN site. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 13, 2004 You'll want to use the diff pistons also - or modify the combustion chamber. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted July 15, 2004 Just get a whole E28 Tim, put your old engine in it and have it as a daily driver http://www.trademe.co.nz/Trade-Me-Motors/C...on-13587390.htm Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 15, 2004 E30-323ti said: Just get a whole E28 Tim, put your old engine in it and have it as a daily driver http://www.trademe.co.nz/Trade-Me-Motors/C...on-13587390.htm your a thinker you are! Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted July 16, 2004 buy an e30 wagon Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 16, 2004 bumpstop325 said: buy an e30 wagon cept that ain't gonna have your 328e or 325e block is it? Quote Share this post Link to post Share on other sites
