lidistick
BBS RS?
Easy enough to replace the centre cap.
Second Inspection they look like standard basketweaves
Edited by jeddy
Wrong offset for e36, fit 5's and 7's.
E28's E34's, most of the bigger pre E39 stuff I believe, Brent and Marty will know.
They are BMW Style 5's made by BBS
They have been on there for ages, I would have bought them if they fitted over the Brembo's :(
Hmmmm the web tells me that are likely to be from an e38 but do fit perfectly well on an e28.
If I had an e28 I would be all over them, but sadly the touring needs to go before I can get back into an old car again :(
Anyone got a manual m535 for sale ?
style five are three piece arent they?.....not quite correct offset for 5 and 7 but near enough...could be quite close to strut if you have a wide tyre.They look almost std basketweave
like mine on the e28 and the e39 , they come with hub sizes , for layter e39 and e38 bigger , and early type from a e34 and e32 . the 8" wide are close to the struts on my e28 AND SOME TYRES will rub the front strut.
Edited by Brent HARTGE535i
Fair nice wheels, nice and subtle for a fiver
^ would be almost perfect for those with E30 M3 suspension, shame there's not too many of those around in NZ, I think the offset would be a little low for those with E36 gear. (wheel would sit out too far)
