pureboiracer 0 Report post Posted May 11, 2008 hey guys. have a little problem with getting traction in the rear of the e30. apart from wider tyres at the back what can i do to counteract this? cheers oli Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted May 11, 2008 Adjustable camber kit, softer rear springs, better tires? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 11, 2008 cheers. will look into it Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted May 11, 2008 LSD if you don't have one already Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted May 11, 2008 Definitely LSD, I have no problems with traction in the rear. Even on 14" bottlecaps. Quote Share this post Link to post Share on other sites
hybrid 1044 Report post Posted May 11, 2008 tires .. There is a budget tire which when I bought my e30 I couldn't believe how useless they were in the wet... even with and LSD which was actually making the problem worse. They get nick named 'Movie tires' ... basically cause you pull the most insane sideways in the wet, they had nil grip but lots of tread. The rubber compound was probably more suited to desert driving haha .. Quote Share this post Link to post Share on other sites
