Damo 23 Report post Posted May 11, 2008 (edited) Hi all, I am selling my E30 wilwood adapted front spindles, struts (if wanted, lower spring perches removed for coilover conversion) brake rotor hats, rotors, calipers and race pads. Will fit under 16" or larger wheels, and require longer than factory wheel bolts, or fit studs (or I can supply stud adapters) Open to reasonable offers, just wanting to cover the cost of another pair of calipers for my E36 5 stud conversion. I have used them for about 300k's driving. Pictures at E30 335ti Will swap for E46 324mm discs and bilstein or koni E36 front struts. Edited May 11, 2008 by Damo Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted May 11, 2008 Link doesn't work? Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted May 11, 2008 Link doesn't work? Thanks! Edited, try again. Its my E30 33ti project post, near the top of the 1st page. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 11, 2008 fairly keen, how much? and what offset do you need the rims to be? I have a set of 17" rims i want to keep using. Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted May 11, 2008 fairly keen, how much? and what offset do you need the rims to be? I have a set of 17" rims i want to keep using. Cant measure by offset, it really depends on the wheel design and how flat the spokes are at the back. I have fitted 16" BBS RS's, 17" BBS RS's and 18" Rays Sebring wheels to them and they all fitted. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 11, 2008 http://www.bimmersport.co.nz/forums/index....showtopic=11620 looking to put them on this car with these's wheels, Theres a fair amount of room with the standard calipers, Just want to check there will be clearance with bigger ones. Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted May 12, 2008 http://www.bimmersport.co.nz/forums/index....showtopic=11620 looking to put them on this car with these's wheels, Theres a fair amount of room with the standard calipers, Just want to check there will be clearance with bigger ones. Should be fine, you are welcome to come and try them out if you like? Quote Share this post Link to post Share on other sites
tune 0 Report post Posted May 14, 2008 How much do you want for them? Is there any change of standard e30 wheels fitting over them? what area in nz are you in>? (top wheel in pic) http://www.bimmersport.co.nz/forums/index....st&id=14157 Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted May 16, 2008 How much do you want for them? Is there any change of standard e30 wheels fitting over them? what area in nz are you in>? (top wheel in pic) http://www.bimmersport.co.nz/forums/index....st&id=14157 I highly doubt it, 16's hug them nicely. Quote Share this post Link to post Share on other sites
HELLBM 1675 Report post Posted May 17, 2008 Will swap for whatever E36 stuff you require. Regards Ray 0212435526 Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted January 12, 2009 OK I have long since upgraded to the 6 pots, so the 4 pot setup is up for sale (Not swap) if anyone is interested. Cheers, Damo Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted January 12, 2009 how much for the set up? cheers Quote Share this post Link to post Share on other sites
mops 4 Report post Posted January 13, 2009 I'm keen, but what $$$ are you looking for ? Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted January 13, 2009 Ashkan!! Do IT! Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted January 13, 2009 I'm keen, but what $$$ are you looking for ? Prices have been PM'ed to the people asking, cheers! Quote Share this post Link to post Share on other sites
