sweetm3 181 Report post Posted May 13, 2008 (edited) Hi Guys pulled the rotors etc off today, including disconnecting the handbrake cable from the expanding lock. The problem is once I have fitted the cable I'm not sure if I have fitted it the right way round, it seems to fit in both directions ????????? Which way is right, Large pin at the top or bottom Edited May 13, 2008 by sweetm3 Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted May 13, 2008 Just for anyone else that may do what I did. The big pin goes at the bottom, your lower brake pad should engauge first when your handbrake is applied. Quote Share this post Link to post Share on other sites
