hybrid 1045 Report post Posted May 13, 2008 Hey fellas, As you may have seen in recent threads I'm having issues with my e46 330i gearbox. Glenn @ Botany motor worx wants to try a 'known good' MAF .. Unfortunitly the one I had planned to put in to test couldnt be found. I have a bit of a big ask, I need someone with a 330i / 330ci that would be willing to lend me their MAF sensor. I would need to swap it for a week or so while we monitor things. I would by a new one but they are about $1000 .. its a bit much to just check if it is the problem or not. It would be professionally changed over at glenns work shop and back. This would be for the greater reseach of this problem thats been plaguing e46's around the world. And I can offer my services to the helper with a professional look photoshoot of their car. Cheers Quote Share this post Link to post Share on other sites
wild_weston 0 Report post Posted May 13, 2008 Unfortunately I'm in wellington and use the car every day. Elmarco has a 330ci and a new member iball has a 330i. These are the only other 330s I know of (apart from yours). You might want to PM them to see if they can help. $1000 for a sensor is a bit crazy. Other option might be to try and find one in a scrap yard (rare I know) and see if they will only charge you to borrow it for a week. Good luck with your search. Quote Share this post Link to post Share on other sites
