Huttey 0 Report post Posted May 20, 2008 Hi, does anyone know of a place in Wellington that fixes the well known problem of faulty solder joints in the ABS pump which result in ABS and DSC being turned off. If not Wellington anywhere in NZ. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted May 20, 2008 Hi, does anyone know of a place in Wellington that fixes the well known problem of faulty solder joints in the ABS pump which result in ABS and DSC being turned off. If not Wellington anywhere in NZ. We use Powerstop Engineering in Tauranga for all our pump repairs. Comes with warranty, pump flush, bench tested and fault codes cleared ( for those without a scanner or reset tool ) Ring Rob (07) 5788909 Quote Share this post Link to post Share on other sites
Huttey 0 Report post Posted May 21, 2008 Thanks Glenn I sent you a PM Quote Share this post Link to post Share on other sites
