skuxbeemadelux 0 Report post Posted June 2, 2008 my water pump has giving up and im wondering wwat the water pump runs off?do i have to touch the timing?or is just run off anthor belt as i wana change it?? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted June 2, 2008 The timing belt tensioner spring is set against the water pump, so you will have to inspect the timing belt when you replace the pump to make sure it hasn't slipped when you release and then reset the tensioner. If the cambelt is due for a change soon, you would be well advised to do it as there is no extra work involved as you have all the covers off and the cooling system drained, and the belts are only $35-50. Quote Share this post Link to post Share on other sites
