User Name
Engine swap vs water on cylinders
Hi Guys
Ive being offered a e34 535i 1988 engine and was wundering how much missing i would have to do to put it into my e28 and does it need anything extra done except for swaping over the sump,
i currently have a e28 528i which after taking the cylinder head off on the w.e found water sitting on top of 4 of my cylinders (gutting) - looked for cracks couldnt see any and dont know if head is warped
now is it worth doing the engine swap or fixing the 2.8ltr engine
if i do the swap will i need to get a cert, wouldnt think so cause not 20% power gain
Any knowledge or help would be apperciated
Hi Guys
yes a e34 motor will go into your e28, after swapping the sump and oil pump.will need to run the e34 ecu and adapt the loom to your plugs etc.not difficult,do the research on mye28 forum,e34 forums.
not sure bout cert.e34 motor does 218hp depending on condition.
i have a 2.8 head on the shelf.cheaper,easier,faster/turn around
be hearing from you
