bimmer boy
17" Advani Toreno's
a person i know bouhgt a set of advanti toreno's but they dont fit his car so he wants to sell them
they are 4x100
17"
with tires
but doesnt hav bolts and that
$1100
Are they the 10 spoke ones? If they are I test fitted some to my car, look real good and they fit pretty good as wel.l
im pretty sure they quite simple 5 spoke mags.
i think they will still look very nice on an e30
yea they are 5-spokes will look mint on a e30 im considering buying them myself
but of cors i will get them cheaper! :P
i do hav pics but my scanner has packed a sad so it may take a while
Guest Andrew
they won't fit your car either.
are they RWD offset? If they are front wheel drive offset they wont fit on BMWs, (unless you buy spacers but im not sure about that)
Its not the offest you have to worry about, if it a 7" wide rim it will clear the front struts with a front wheel drive off set, it the brake caliper you got to worry about and that somes down to the shape of the wheel.
Guest Andrew
i.e the offset ...
QUOTE (petone @ Jul 25 2004, 03:54 PM)
i.e the offset ...
which was what i was asking when i was asking if they were front or rear wheel drive offset.....
i dunno if they are front or rear wheel drive offset... i should find out
but i have lost intrest in them now and cant be bothered .. meh
i wasnt meaning you man, my response was aimed at petone who said it wasnt the offset that mattered, and then preceeded to describe what the problem was, which was infact in a long-winded kind of way, the offset!!
I personally dont care - i have 5x120 on my BMW, and my wagon is 4x114.3, so its not like im going to buy them.... hehe
What I was trying to say was that if its a front wheel drive offset it can still fit without spacers, depending on the shape of the wheel. Also, the offset is a measure of how far away the mounting point on the hub is away form the centeline of the rim, if you get what i mean by that. Basically, the only way to see if a wheel that has front wheel drive offset will fit is to test fit it.
i would have said that to work, wheels would have to be round in shape.... hahaha
