tibbs.james 1 Report post Posted June 4, 2008 Hi guys as above I need 320i E30 ABS half shafts Mine are clonkys and rooted. was quoted $400 from Eurorec in CHCH Aparently hard to find because they are ABS If somebody has some really good ones and can do better on the price I would be rather happy Cheers James Quote Share this post Link to post Share on other sites
*rUstY_nUts* 9 Report post Posted June 4, 2008 Hi guys as above I need 320i E30 ABS half shafts Mine are clonkys and rooted. was quoted $400 from Eurorec in CHCH Aparently hard to find because they are ABS If somebody has some really good ones and can do better on the price I would be rather happy Cheers James Go for the 325 Motorsport ones. They have larger universals....or you'll be back to square one again Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 4, 2008 I'm happy staying with 320i Ones. I don't thrash my car ( fuel is too expensive to waste it ) I just want properly working rear suspension & driveline. Otherwise i would need another diff. I already have the correct ratio low mileage diff in my car not long fitted. 320i ABS Halfshaft are the only one's im considerg. Unless somebody can do a Good Cond 3.5 or 3.7 ratio diff Inc 325 ABS Halfshafts for really cheap. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted June 4, 2008 I have a 3.7 diff and a 320i 1990 e30 low km rear set up for abs set up. Pm me with an offer if your keen. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 4, 2008 (edited) If it's already a medium case diff the 325 axles will fit with no modification necessary, they are stronger axles. BTW I have a 3.64:1 medium case diff out of a 325 for sale, with new side seals & new oil fitted.... $300....no axles though. Try Ray @ HELLBM Cheers Glenn Edited June 4, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 5, 2008 Thanks for the replys guys I have a 3.7 diff and a 320i 1990 e30 low km rear set up for abs set up. Pm me with an offer if your keen. Would you sell just the axles? I have no room for a completre rear end. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted June 5, 2008 yeah can do. Can you send me an image of the parts you need. The rear end is still all intact but i will pull it apart this weekend for you if i get a chance. [email protected] Quote Share this post Link to post Share on other sites
