topcat 11 Report post Posted June 6, 2008 Hi Guys looking for info on the b35,flow info mainly. need the info to start to calculate the VE,compression stroke,cam timing etc. also to make some base numbers,before we start porting,stroking,headers etc. Next,who knows where to find springs,namely double valve spring setup for the b35 as its going back together soon. just had a 'trail' run with fitting larger exhaust valves.3mm larger at this stage. the standard exhuast valve basicly falls into the bored ports. looks awesome,hope the flow bench will also show good results. cheers,and yes will take some pic's etc-marty Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 6, 2008 Hi Guys looking for info on the b35,flow info mainly. need the info to start to calculate the VE,compression stroke,cam timing etc. also to make some base numbers,before we start porting,stroking,headers etc. Next,who knows where to find springs,namely double valve spring setup for the b35 as its going back together soon. just had a 'trail' run with fitting larger exhaust valves.3mm larger at this stage. the standard exhuast valve basicly falls into the bored ports. looks awesome,hope the flow bench will also show good results. cheers,and yes will take some pic's etc-marty You might get the right info off this site http://www.m535i.org/officers/ra/article.html#motor Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted June 6, 2008 (edited) You might get the right info off this site http://www.m535i.org/officers/ra/article.html#motor cheers for that,but had a look around this site before i asked,couldnt see/find any numbers.or have i missed something? Edited June 6, 2008 by topcat Quote Share this post Link to post Share on other sites
mr E34 11 Report post Posted June 6, 2008 (edited) Ireland Engineering for BMW, have you looked at their site? ( double valve springs/valves etc) go to bmw other for e34 Marty, where do you go for flow bench testing of the head? http://store.nexternal.com/shared/StoreFro...ount2=364478707 Edited June 6, 2008 by mr E34 Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted June 6, 2008 Ireland Engineering for BMW, have you looked at their site? ( double valve springs/valves etc) go to bmw other for e34 Marty, where do you go for flow bench testing of the head? http://store.nexternal.com/shared/StoreFro...ount2=364478707 at the moment i'm making friends with airplane guys out at ardmore,they crack tested my block for good rates i'll look at ireland,hoping someone local had knowledge Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 6, 2008 prolly preaching to the converted but the b35 had increased valve sizes over the b34?.The B35 was e34 only wasnt it? Quote Share this post Link to post Share on other sites
mr E34 11 Report post Posted June 6, 2008 (edited) Have a read here Topcat! Interesting article. M30 Alpina engine, 261PS, approx 250-255@ flywheel if your lucky.(somehow i doubt those figures back then) NOTICE THE EXTRA HEADWORK,HEMISHERICAL COMBUSTION CHAMBERS WHICH ALPINA FAVOURED. http://www.autospeed.com/A_109805/cms/article.html Edited June 7, 2008 by mr E34 Quote Share this post Link to post Share on other sites
