topcat
B35 head info please
Hi Guys
looking for info on the b35,flow info mainly.
need the info to start to calculate the VE,compression stroke,cam timing etc.
also to make some base numbers,before we start porting,stroking,headers etc.
Next,who knows where to find springs,namely double valve spring setup for the b35 as its going back together
soon.
just had a 'trail' run with fitting larger exhaust valves.3mm larger at this stage.
the standard exhuast valve basicly falls into the bored ports.
looks awesome,hope the flow bench will also show good results.
cheers,and yes will take some pic's etc-marty
Hi Guys
soon.
You might get the right info off this site
http://www.m535i.org/officers/ra/article.html#motor
cheers for that,but
had a look around this site before i asked,couldnt see/find any numbers.or have i missed something?
Edited by topcat
Ireland Engineering for BMW, have you looked at their site? ( double valve springs/valves etc)
go to bmw other for e34
Marty, where do you go for flow bench testing of the head?
http://store.nexternal.com/shared/StoreFro...ount2=364478707
at the moment i'm making friends with airplane guys out at ardmore,they crack tested my block for good rates
i'll look at ireland,hoping someone local had knowledge
prolly preaching to the converted but the b35 had increased valve sizes over the b34?.The B35 was e34 only wasnt it?
Have a read here Topcat! Interesting article.
M30 Alpina engine, 261PS, approx 250-255@ flywheel if your lucky.(somehow i doubt those figures back then)
post-1048-1212731347_thumb.jpg NOTICE THE EXTRA HEADWORK,HEMISHERICAL COMBUSTION
CHAMBERS WHICH ALPINA FAVOURED.
http://www.autospeed.com/A_109805/cms/article.html
Edited by mr E34
