camera doctor
E39 Drive + Play Install Help
Maybe Jochen or Hotwire can help me here..... :)
I have a Harmon Kardon Drive + Play to install to my 1997 E39 540i.
The options are FM Wireless ( Rather not )
RCA Input
Wired FM Modulator
So, my choices really are 'AV' Input or the FM wired Modulator, that plugs inot 'standard' type aerial socket.
I have the bits Jochen sent me to hookup the AV input, but am I right in remembering that it only is Mono?
If I go with the FM wired system, where do I find the Aerial socket - I'm guessing in the boot? If so, is the plug a 'standard' car stereo type, or am I going to need a special BMW plug/socket combo?
TIA
Antenna connector is standard DIN type
For stereo AV in you have following choices:
FM modulator
CD emulator
Tape deck wiring
For mono AV in you can use TV AV input.
Thanks, this is probably the easiest route - where do I find the antenna connector - boot or dash?
I have read on USA forums that 'hot wiring' through the tape input gives poor quality sound, and if I go the CD input I guess I would loose the function of the current CD changer?
Thanks for your help.
Greg
Greg
Hi,
You have ex-Japan E39 with TV/nav if I recall correctly.
Radio module is the lump behind the rear passenger seat trim in the boot.
Left hand lump = radio module (radio tuner), right hand lump = video module (TV tuner)
Remove boot trim to access: trim comes out as left+middle+right in one piece, can be angled under nav.
You can wire in parallel to CD and fit a relay with a remote switch that then switches the audio between CD and iexternal audio source.
Then either leave a CD fitted to the changer and hit 'play', the CD input will be activated, and then you just switch the audio to external. Or get a CD emulator, and have that included in the switch, so that you don't have to have a CD running all the time (ie: stops the laser running permenently)
