camera doctor 25 Report post Posted June 13, 2008 Maybe Jochen or Hotwire can help me here..... I have a Harmon Kardon Drive + Play to install to my 1997 E39 540i. The options are FM Wireless ( Rather not ) RCA Input Wired FM Modulator So, my choices really are 'AV' Input or the FM wired Modulator, that plugs inot 'standard' type aerial socket. I have the bits Jochen sent me to hookup the AV input, but am I right in remembering that it only is Mono? If I go with the FM wired system, where do I find the Aerial socket - I'm guessing in the boot? If so, is the plug a 'standard' car stereo type, or am I going to need a special BMW plug/socket combo? TIA Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 13, 2008 Antenna connector is standard DIN type For stereo AV in you have following choices: FM modulator CD emulator Tape deck wiring For mono AV in you can use TV AV input. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 13, 2008 jochen said: Antenna connector is standard DIN type Thanks, this is probably the easiest route - where do I find the antenna connector - boot or dash? I have read on USA forums that 'hot wiring' through the tape input gives poor quality sound, and if I go the CD input I guess I would loose the function of the current CD changer? Thanks for your help. Greg Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 14, 2008 camera doctor said: Thanks, this is probably the easiest route - where do I find the antenna connector - boot or dash? I have read on USA forums that 'hot wiring' through the tape input gives poor quality sound, and if I go the CD input I guess I would loose the function of the current CD changer? Thanks for your help. Greg Hi, You have ex-Japan E39 with TV/nav if I recall correctly. Radio module is the lump behind the rear passenger seat trim in the boot. Left hand lump = radio module (radio tuner), right hand lump = video module (TV tuner) Remove boot trim to access: trim comes out as left+middle+right in one piece, can be angled under nav. You can wire in parallel to CD and fit a relay with a remote switch that then switches the audio between CD and iexternal audio source. Then either leave a CD fitted to the changer and hit 'play', the CD input will be activated, and then you just switch the audio to external. Or get a CD emulator, and have that included in the switch, so that you don't have to have a CD running all the time (ie: stops the laser running permenently) Quote Share this post Link to post Share on other sites
