kiwiland 3 Report post Posted June 15, 2008 Anyone know the ideal idling speed for an E39 530 Auto (2001). Mine seems to be set at 700 rpm and when waiting at the endless traffic lights you can almost watch the consumption reading rise. With the cost of 95 being what it is seems a waste to have the engine idling at that speed Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted June 15, 2008 700 is about the average for nearly all cars isnt it? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted June 15, 2008 700 is about the average for nearly all cars isnt it? Yup Quote Share this post Link to post Share on other sites
BMW012 4 Report post Posted June 15, 2008 My car idles at 0kph... hahaha Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted June 15, 2008 My car idles at 0kph... hahaha So does everybody else's. We're talking RPM. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted June 15, 2008 Found this in the Bentley service manual on idle speed Idle speed control valve. This regulates the idle speed by re-directing air around the throttle valve. It is mounted on the under side of the intake manifold adjacent to the dip stick tube. The idle speed control valve incorporates a two coil rotary actuator and the ground side of each coil are pulsed simultaneously by the ECM . A faulty Idle speed control valve sets a fault code and the MIL is illuminated when the OCB11 fault criteria is exceeded, Bentley service manual. I have read on an American forum also of these seizing up and coursing problems maybe yours is sticking slightly and could be giving the symptoms you mentioned. Cheers Allan Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 15, 2008 700 sounds about right (as already said) It is predetermined by engine management system, a fault in the system would generally give a sporadic uneven idle. Even if you were able to slow it down - it would only be by 50 -100 rpm max - which would have an absolutely negligable effect on fuel consumption & at which time you would probably introduce other issues. Quote Share this post Link to post Share on other sites
